Our Jon in AutoSpeed!!! This car was one of the best and cleanest looking R32's around IMO. I loved it.
If you can remember back to our article Pre-Owned Performance - Nissan Skyline R32 GTS-t you’ll know that the Nissan R32 Skyline GTS is a much better vehicle than its reputation suggests. No, it doesn’t have the GT-R’s giant-killing RB26DETT or the R33’s RB25DET but it’s still a great overall package. Consider the R32 GTS’s modest 1320kg kerb mass and you’ll come to appreciate why the oh-so-smooth RB20DET makes it a good thing.
And John ******* late 1993-built R32 is just the machine to prove its potential.
John picked up his Type M R32 about 2 years ago with just an aftermarket filter under the bonnet. John liked the Skyline’s smoothness, refinement and style but – having owned a VR4-powered Cordia, an 11 second Torana, RX-2 and various go-fast Commodores – its all-out acceleration didn’t get his blood rushing.
There was no hesitation when John made his first mods – they were so obvious every man and his dog can tell you that the stock exhaust and intercooler are hopelessly restrictive. The factory exhaust system came out and John offered a 3 inch mandrel system to the back of the turbocharger. Oh, and John also replaced the existing aftermarket filter with a new HKS pod fed by a 3 inch cold air pipe.
John shopped around for an upgrade intercooler to replace the factory item and settled on the popular Hybrid 600 x 300 x 76mm core. This is a pretty big ‘cooler so its no surprise the bumper had to be sliced to make space. The intercooler plumbing was fabricated by John and his brother-in-law.
The R32 isn’t John’s sole project car but when he discovered a Mines computer hiding in a R32 Skyline half-cut he bought (to re-power a Sil80) he roped it in for action on this machine. We’re told the Mines ECU eliminates or lifts the speed cut, boost cut and rev limit. John had been told all about the standard Nissan ceramic tubocharger’s reliability problems at high boost so he wisely kept the boost increase fairly mild – just 10 psi. A home-made bleed valve and restrictor arrangement allows this increase.
Power at this stage was about 215hp at the wheels on Paramount Performance’s Dyno Dynamics chassis dyno. Not bad, but the engine had the intercooling and breathing capacity to support a lot more...
As John pondered a turbo upgrade that would safely allow more boost, a mate offered for sale a second-hand Mitsubishi TD06-19C turbo with internal wastegate. Perfect! Or almost perfect...
To fit the TD06 John retained the standard RB exhaust manifold but used longer studs and a 12mm spacer plate to mount the turbo further away from the engine (to provide necessary clearance). We’re told the TD06 had the same stud pattern as the factory exhaust manifold so there were no problems with mounting hole alignment.
The bigger huffer didn’t give the same sort of throttle response as the old turbocharger but it did provide a lot more top-end power. With boost pressure set to a high of 21 psi, the TD06 pushed 270hp at the rear wheels. On the downside, it had problems over-boosting and John tried a bigger exhaust housing to fix the situation. This successfully prevented over-boosting but caused unacceptable lag. Top-end power also went virtually unchanged.
A newer, more efficient turbocharger was what the doctor ordered.
Recognising the limits of the TD06, John stepped up to a GT28-type ‘440hp’ roller-bearing turbocharger that is designed to suit CA and SR-series Nissan fours. Unfortunately, the RB20DET engine employs a T3-style turbo flange while the CA and SRs use a T25/T28-flange. At this stage most people would leap to the conclusion that an aftermarket exhaust manifold is needed – but not Do-It-Yourself John!
With the help of John’s brother-in-law, the original turbine flange plate was cut off the RB manifold and a drilled-to-suit 32mm thick mounting plate was welded on. John says the original manifold was heated and maintained at a high temperature while the new adaptor plate was welded on using stainless rod. A key factor to avoid cracking is to control the rate of cooling once the plate has been welded – let the manifold cool rapidly and it will lead to cracking problems.
At the same time the turbo was being swapped, the existing Mines computer was ripped out of the passenger’s kick panel and a plug-in MicroTech LT12 ECU took over. The MicroTech unit contains a MAP load sensor so John made the most of it and removed the factory airflow meter to reduce intake restriction. A set of six modified Skyline GT-R injectors and a Malpassi adjustable reg team with a R33 GT-R in-tank pump and a Bosch 909 high-flow external pump. The ignition is stock.
With its new roller-bearing turbocharger and tuned MicroTech computer, the car punched out a fairly easy 307hp at the wheels on 18 psi. Interestingly, John then decided to alter the cam timing (using custom adjustable sprockets) and found about 13hp more at the wheels - with only a touch more lag. John says the current cam timing specs are: inlet cam timing retarded 2 degrees and exhaust cam timing advanced 6 degrees.
As you may have noticed in our pics, a polished oil breather catch can and a GReddy Type S blow-off valve were also installed at this time.
The standard Nissan driveline is very strong, but when you add a no-slip ‘600hp’ brass button clutch, the poor ol’ gearbox doesn’t receive much slack when the rear tyres hook up. This is John’s fourth gearbox – he’s blown a second gear, third gear and an output shaft! The diff is the original viscous LSD – no problems with it so far.
John is pretty keen on the drift scene and has his R32 set up for easily controllable power slides. Tein HR coil-overs, pillow-ball upper mounts, a R32 GT-R rear swaybar and a disabled HICAS system give John the handling balance and response that’s essential when getting sideways at, well, a considerable speed... If he ever gets into trouble, John can always stand on the R33 Skyline brakes which are currently being bolted in.
Cosmetically, John’s R32 is surgically clean. The factory white paint is immaculate, he’s removed the standard rear spoiler and the bumper is a base-spec R32 item that’s sliced to suit the ‘cooler. The wheels fitted during our photo shoot are 18 x 8s wearing 235/40 Bridgestone S02s.
Inside, John’s car is inexplicably fitted with a R32 GT-R-like trim. John says he’s seen other GTS Type Ms with a conventional interior trim, so we can only guess the GT-R trim package came out in the late-model R32 Type Ms. John has also added an AutoMeter boost gauge, aftermarket steering wheel, gear knob and pedals plus a JVC MP3 sound system with a 12 inch sub. All the essentials.
At this point in time it seems John has taken his R32 GTS about as far as he intends. As a result, he wouldn’t mind selling it to put some extra cash toward his other project – his dyno queen/show car Sil80.
Hmmm. If this R32 is only a ‘warm up’, we dare to imagine what that l’il beast will be like!
Footnote - if you’ve got around approximately AUD$23,000, John is willing to let his R32 go to you. If you’re genuinely interested, John can be contacted at [email protected]
WHITE R32's skyline which I believe he recently sold to fund his new project. Interesting write up, I never knew most of that stuff.
Pics below.
https://www.sau.com.au/forums/topic/62063-autospeed-yld32/
thanks guys much appretiated..... yeah sadly its gone now but now i have a sil80 ground up project yeah i know i know how could u go to an s13.... but i cant even answer that myself :cheers: what started as a quick accident repair and touch up is now a full strip and full respray inc engine bay full susp redo inc coilovers engine mods etc etc etc lol
actually the gearbox count not as bad as that when they rang and got details i thought mick said how do the rb20 gearboxes hold up and i said ive broken 3rd in my first but ive seen broken output shafts and second gears.... either that or i heard the wrong question or just gave the wrong response.... bad phone service does that to you....so yeah i only ever broke 1 box myself...
the ol' 20 boxes held up good i rekon like everything just depends how u drive it im sure i could break a 25 box also but it would take more thrashin hehehe....
i just hope the new owner respects the car and the power it has (albeit not massive hp but enough to get u into trouble) and has fun at the same time!!!!!!!
https://www.sau.com.au/forums/topic/62063-autospeed-yld32/#findComment-1174205
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
