Guest GR33DyMANGO
once the turbo timers on.. couldnt someone get in the car (ie break window etc) then once inside just keep pushing the turbo timer button to the longest amount of time then just keep pushing it??? someone could potentially keep driving until they reach their garage where they strip your car etc....
im sure it happened to my friend as a joke... but his was just driven round the corner.
hehe yeh good point but u can disable that with a screwdriver and a bit of effort.
Remember the simpsons ep where Mr Burns gives Bart the ferrari and he cant even see over the wheel. ahh i loved that ep:lol:
  • 2 years later...
with my car being an auto u cant get the keys out of the ignition unless its in park and cant change gears without the keys being in the ignition. hell u cant go into reverse unless u put ure foot onto the brake.....
but even still if the people can find ure TT then they have direct acces to ure ignition wires and can just satart it coz most immobilizers dont activate till 30 secs after the car stops, unless u have ure alarm wired in to allow it....
Bambam when you say they "searched" your car what exactly did they do and where did they look?:eek1:
Searching Persons without a Warrant
The Police Powers and Responsibilities Act permits police officers to search persons without a warrant.
The authority of the police to search a person without a warrant is dependent upon the existence of a ‘prescribed circumstance’. If a police officer reasonably suspects that a ‘prescribed circumstance’ exists. The prescribed circumstances in which an officer may search a person without a warrant includes circumstances in which the person is reasonably suspected to be in possession of:
a weapon, knife or explosive;
an item which the person intends to use to cause harm to any person;
a dangerous drug;
stolen, illegally obtained or tainted property;
evidence of the commission of an offence punishable by a minimum of seven (7) years imprisonment, which the police officer reasonably suspects may be concealed or destroyed if a search is not conducted;
an implement of housebreaking, motor vehicle theft or drug use.
Searching Vehicles without a Warrant
An identical set of rules apply to police searches of vehicles without a search warrant. A police officer may stop and search a vehicle, together with anything in it, if any of the above ‘prescribed circumstances’ exist.
When searching a vehicle, the police are allowed to enter, re-enter and stay in the vehicle as often, and for as long, as is necessary to properly carry out their search. The police also have the power to move a vehicle to an appropriate place for a search, in particular if it is impracticable to search the vehicle where stopped.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
