Are any of you honestly surprised that we have some tossers driving Skylines (and giving the rest of us Skyline owners a bad name) when so muchy of the talk about them in this forum & elsewhere is about how much power we get out of them.
Logically if a person spends a lot of time & money modifying a car to produce more & more power then they're going to want to use it.
Now, when you consider the speed limits and the penalties for breaking the law, you have to wonder why anyone needs 500hp at the wheels, but people keep doing it.
No-one's perfect - I've had more speeding fines than I care to remember - but I like to think that the most important consideration when driving (and in life) is how your actions affect other people.
Happy (& safe) driving
Guest Boxhead
yes im in the boat of trying to show of once haha, ended up good for me, a new paint job on the car.. but anyway
i think most crashes come down to a couple of things a) common sense and B) maturity...
like fair enough ppl out there will say im only going to get worse now having a turbo car, but since its manual, and its the first manual, i find myself im taking it real easy, my changes are too slow to race anyone coz ill loose, so i dont even bother haha,
my takes offs are even worse..
but i do think as per always its a case of bad apples makin the rets look bad, you will always have those types of people in every type of car, wether it be v8 or turbo 6, or turbo 4 for that matter.
I dont really agree about skyline drivers been more reckless than the general population. Whenever i am out at local cruise spots like down in wollongong or some of the areas in sydney it is generally the skyline drovers who seem the bestbehaved. Its always seems to be the idiots in old VLs or the little turbo charade darting in and out of traffic. I think most people with a decent skyline generally value their car or cant afford to crash it, possibly because someone driving a done up charade or swift will be paying about 1/3rd what a young skyline driver does for insurance.
Then again i think there are stupid drivers everywhere you look. The type of car doesnt seem to matter. Id say we here would just notice skylines alot more.
Well, hands up anyone here who owns a skyline (or any other fast car) and doesn't give it any stick at all... Sure, some of us may confine our need for speed to the track, but it's my guess that one of the main reasons people buy skylines is the performance.. I suppose each of us has different ways of enjoying the performance of our cars - some better than others.
Darting in and out of traffic isn't the only way to be a tool on the road - how about driving fast through heavy fog, or on a cold winters night when the road's likely to have ice on it. 100k's an hour on a country road at dawn and dusk seems pretty stupid to me, especially after I hit a roo a few years back. None of this requires you to own a skyline.
All it comes down to is the drivers maturity. I've seen falcons, commies, astras, pulsars, lasers, lancers, s15's, exa's, etc with idiots behind the wheel.
But guys, good / bad driving is all on a scale. And no matter how bad you are, there's always someone in a Volvo who's worse :)
I dont get any runs in my 32GTST, mainly because it looks just like a GTR and most perth commie drivers seem shit scared of it. But if i hop in my brothers 180SX, you can guarantee ill get some tool wanting a run within 3 sets of lights.
Only runs ive had on the street off the lights has been late at night and usually against another skyline owner, simply because he knows it aint a GTR :)
Red17
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
