matalic black
rb25det 110 000k's
richo racing ecu
3000 pound nismo clutch only like a month old
light weight flywheel
s&b pod filter, custom cold air induction box
3" exhaust from the turbo back hiflow cat
400 hp fuel pump
custom surge tank
apexi electronic boost controller
big front mount intercooler
malpassi rising rate fuel pressure regulator
custom front bar with r31 house front spoiler
alarm
impul rear bar (extremly rare)
16" volk/rays engineering rims in custom sliver, brand new 225s on the back and brand new 205s on the front
sony cd player
interior is like brand new, keeped in excellent condition, serviced every 4000 km with only the best products
located in brisbane, asking $13000 ono
i have tons of pics u can check some of them out here :
http://au.pg.photos.yahoo.com/ph/mattnugen...t2004/my_photos
https://www.sau.com.au/forums/topic/62549-qld-r31-import-four-door-gts/
  • 1 month later...
this car has to be sold asap due to me being in bad money troubles, the price is 13000 but is negotiable, if your after a sick,fast import 31 that will stand out from the rest then this 31 is a one of akind in Australia.
  • 1 month later...
  • 1 month later...
ok guys the car needs to be sold asap, i've got serious money issues so im dropping the price to 10 grand!
considering the amount of time and money i've spent on this 31 it is an absolute steal at that price.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
