Ok all you knowledgable dudes out there, my daughter's ex-beau's 200sx s14 won't start. RAC had a look and no luck, said seems to be an electrical prob.
He drove it home and a short time later went to go out but wouldn't start. No forewarning.
Someone has suggested it could have something to do with immobiliser. Cranks over so not sure if that would be the prob. He's having it towed to my place now to store it till Monday.
Wondering if anyone has had the same thing happen?
Thanx in advance.
https://www.sau.com.au/forums/topic/62947-s14-wont-start/
If you think it is electrical, first place to look is the CAS and ignitor - check that the plugs are properly in place - good idea to check all other plugs on the harness too, not forgetting things like the alternator.
Check all the wiriing to make sure there are no signs of wear, brittle wires from heat (around turbo) or any melted bits.
Also it may be worth checking the CAS to make sure it isnt loose and has moved.
Another one, check the coil packs and plugs to make sure they are in good condition.
Fault finding can be a bitch, good luck.
https://www.sau.com.au/forums/topic/62947-s14-wont-start/#findComment-1185374
Thanx guys, some good points there.
Will check it out when he comes down tomorrow arvo. Hopefully it will be something minor like a loose plug etc and not a catastrophic failure of some component.
Not familiar with CAS so will look up the net for info on that b/4 tomorrow so I will know what the hell I'm looking for.
https://www.sau.com.au/forums/topic/62947-s14-wont-start/#findComment-1185446
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
