I have an R33 Skyline GTS-T Turbo automatic.
Anyone had a problem with the tacho (RPM) part of the cluster not working properly?
Mine seems to gradually run clockwires from 0 all the way round past 9000rpm over the space of about an hour. I have tried to obtain a second dash cluster but I cannot seem to find one cheap. It has worked once or twice at times, but very rarely.
Is this an issue with the tacho, or the connection?
Anyone know where to get a dash cluster fairly cheap?
Thanks.
BOOMAU
https://www.sau.com.au/forums/topic/63005-my-tacho-is-screwed/
Pull out the instrument cluster. you have to take out the plastic dash shroud that covers the steering wheel, and the one around the aircond/deck. There are 3 plugs so dont worry about not being able to put it back together again. Unplug and reconnect. You may want to check the connection running into the ECU in the passenger side kickpanel...this is held in by a bolt so doubtful that its that.
May be the actual tacho itself, surely you can just buy a replacement tachometer and slot that into the intrument panel instead of buying the whole lot. you could probably give it a crack yourself and if you run into any problems go see an autoelec.
Pulled out the whole dash, checked all the connectors to make sure that they were all securely conntected and replaced it all.
Still not working....
Anyway, because there is power going to the tacho I really dont know what is going on, the tacho is still moving slowly from 0rpm to over 9000rpm over the space of 1/2 hour.
Obviously the tacho is working on some level, idle and running of the car is fine, I just got no idea what rpm I am doin and it is really starting to bug me.
Thanks for the help, guess only other solution is to try another tacho, cluster and see if that works.
BOOMAU
mine does what yours does too, and fcuk, it is the most annoying ever!!! Its almost comming to the point not im just going to leave it faulty, and run an aftermarket 3 3/4" tacho.. seems like a better idea to me.. plus might be cheaper!!!
let me know if a new cluster fixes it though..
I had (still have) problems with the speedo which is a common prob due to wind backs.
Goes straight to 60km/h weather your doing 10km/h or 120km/h
I wasn't going to spend money fixing it when you can get an APEXi RSM instead.
Exactly what i did and i love it :D
Good for those 0-100 times too. and removes the speed cut.
..and looks sexy!
Probably get one 2nd hand for $250 maybe?
But yeah, has revs too and mine is just velcro'd inside the dash
Plus everyone knows having a quick glance at a tacho or speedo neddle is easier to recognise to the brain than a digital readout. Plus a tacho with its needle design looks heaps better when you rev it up.... Its like almost there, almost..... yeah redline....
True, but when they check it if i get pulled over it goes to zero whcih is correct.
Hehe :D
Plus i can get rid of it if cops are around.
Rip it off and hide it under something (unless they search the cabin off course)
Also, you can set it up so the ecreen will flash at any rev level you want.
One bad thing i don't like about it, which doesn't happen very often, is the sun glare off the glass/plastic face. Normal speedos don't seem to reflect at all so you can always see the speed. Not so with the RSM, but definatley livable.
Definatley a cover up option like you said, but so good at it, i aint fixing the speedo.
it happens to mine, but what i did was i pulled out the whole dash bit and if you pull back the front back of the tacho with all the numbers on it tap the unit behind there or check the wires.. i hit mine and had it connected still with the car running and it starting working again.
Wow, might just try that, I had the tacho out yesterday and once I got it out and checked the connectors to see if they were securely in, I just put the stupid thing back.
I might try it again and see if I can pull off the glass front cover and peel back the tacho cover bit and give it a few taps (possibly punches depending on how frustrated I get with it hehe) check the wires and see if that does anything.
Are there any problems just hooking the tacho up with everything else unplugged (ie aircon, hazard, dash light dimmer, etc)?
I wouldn't think so, but possibly thought that if something wasn't plugged in, car would sense that and somehow screw up the computer.
Anyway, thanks all for the ongoing help with this one, if I figure it out, I might post a thread on what I did in detail for others to try.
Hitting the dyno today, with my stock standard R33, hopefully everything is A OK under the hood so I can start tweakin my little baby up.
Cheers all
BOOMAU
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
