My 1st lucky take was an invitation to cruise around the City on Channel[V]'s & Billabong's own touring bus. This comfy beast included:
a full set of Cromie's
Full black leather seating.
2 Plasma Screen TV's
Too many speakers to count + 3 Sub's
Gamecube & Xbox
DVD, CD, TV, AMP the works
Microwave, Fridge, kitchen
and a lot of cup holders.....
It was quite fun driving around and having everyone point and stare at the bus as if there was some big band behind the tinted windows. But you could imagine the look on their faces when we got the bus to pull into macca's and we all jumped out... :headbang:
I offered to sign autographs, but there was no takers
Some pics:
My 2nd Lucky take was after the bus cruise and driving home in my younger brothers VP Commodore. Got pulled over on Elizabeth Street.
now this car included:
1 Working brake light
2 Missing side indicators
2 Differnt coloured headlights
Got away with it clean, no canary check or anything. Just a breath test and off we went.
The Luck spree continued as I was pulled over AGAIN about 1 hour later this time in my Skyline down Flemington road. I don't even need to list the defects as im sure most of you know a Skyline comes with unlimited EPA's and Canary's from the cops at any given time.
Amazingly I was let off again after a short breath test!!
Some more pics:
Now all I need is for my syndicate lotto ticket to pay off for that night, still waiting for the results on that. :cheers:
https://www.sau.com.au/forums/topic/63050-luckiest-night-ever/
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
