Hi guys, this looks like an opportune time for a bit of SAFC, ITC and ECU information dumping......
An SAFC modifies the signal from the AFM to fool the ECU into thinking there is less airflow (this leans out the mixture) or more airflow (this richens the mixture).
An SAFC does nothing for correcting the ignition timing, in fact I have seen cases where it actually does the wrong thing. An example, if you have somewhere in your RPM range where the mixtures are too rich. The SAFC can be adjusted to have the ECU lean this out by telling the ECU that there is less airflow, so it reduces the amount of fuel. The A/F ratios are now good, but what happens to the ignition timing? Well the ECU thinks there is less airflow (than there really is) so it advances the ignition timing to what the ignition map says is correct for that (lower) amount of load.
In my experience that's too far advanced quite often, so I have 2 choices. Either, retard the static ignition timing, which affects all rpm ranges. Even though it might be OK at some RPM's and even (already) too retarded at others. Or, compromise on the A/F ratios and balance it out so I get close to what ratio I want, but don't affect the ignition timing too much.
Now to fix this ignition timing problem you can get an ITC. This sits between the CAS and the ECU and modifies the ECU's firing of the spark plugs. But again this is a compromise as the ITC only has a small number of correction points and it extrapolates in a straight line between them. This is particularly a problem at times (in the RPM range) of rapidly changing boost levels.
As you increase the amount of power and/or boost this "compromising" just gets worse. With an SAFC and an ITC you have (sort of) fixed the A/F ratios and the ignition timing, but you also have the problems of boost mapping, idle stability, load correction for air con, power steering, electrical load, rpm limiter, speed limiter, cold start and run etc etc
If you add up the costs of all the "trickers" it works out more than a Power FC and still doesn't give anywhere near the quality of result. So for a modest power target, an SAFC is not a bad thing, but if you are serious, then an ECU upgrade is the go.
Hope that helps
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745385
Thanks for that reply Sydneykid, my car is also auto and i have a s-afc. But when being tuned on the dyno the tuners had problems with the timing as it caused the car to misfire when they leaned out the s-afc. So if i get my hands on a ITC it will fix my problems? I wish i could get a power fc but im stuck with this problem.
Or would you recommend me to sell the s-afc and buy a e-manage with igniton harness? The only info i havent been able to find out is if the ignition harness will work on the auto with no problems. I dont want to throw any more money around trying to solve it, i just want the cheapest, easiest option which the ITC sounds like it can do.
Cheers,
Matt
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745392
Hi Strutto, if your power targets are modest, then an SAFC is the go. We are getting an auto Stagea shortly and I will stick an SAFC in that. I have a ball bearing hi flow RB25 turbo to go on it, a split dump, 3" exhaust, panel filter, CAI, Autospeed (Norgren valve based) boost controller and an OK intercooler. Should give a nice torquey 200 rwkw to tow the race cars with.
If it doesn't end up meeting my expectations, I might try a piggy back manual Power FC. Leave the inputs to the standard ECU and the outputs from it to the auto. Parrallel up the inputs to the PFC and use it to run ignition, fuel, boost and idle control. I have seen an R33 with a Link piggy backed similarly, it was OK but a little rough on the gearchanges.
Have a chat to Steve-SST, I think he has done a Wolf into an auto.
Hope that helps
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745401
Well once i get the ecu issuses sorted out i plan on doing the fuel pump, fuel pressure regulator, cam gear and then finally highflow the T3. I think that will be enough power for me so is a safc and itc good enough for this setup? Thanks again, Matt
Yep, sure it's a compromise, but not that bad. I had a friend with an SAFC and ITC and he was happy for 3 years, driving everyday + some drag and circuit work.
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745413
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
