Hi guys, this looks like an opportune time for a bit of SAFC, ITC and ECU information dumping......
An SAFC modifies the signal from the AFM to fool the ECU into thinking there is less airflow (this leans out the mixture) or more airflow (this richens the mixture).
An SAFC does nothing for correcting the ignition timing, in fact I have seen cases where it actually does the wrong thing. An example, if you have somewhere in your RPM range where the mixtures are too rich. The SAFC can be adjusted to have the ECU lean this out by telling the ECU that there is less airflow, so it reduces the amount of fuel. The A/F ratios are now good, but what happens to the ignition timing? Well the ECU thinks there is less airflow (than there really is) so it advances the ignition timing to what the ignition map says is correct for that (lower) amount of load.
In my experience that's too far advanced quite often, so I have 2 choices. Either, retard the static ignition timing, which affects all rpm ranges. Even though it might be OK at some RPM's and even (already) too retarded at others. Or, compromise on the A/F ratios and balance it out so I get close to what ratio I want, but don't affect the ignition timing too much.
Now to fix this ignition timing problem you can get an ITC. This sits between the CAS and the ECU and modifies the ECU's firing of the spark plugs. But again this is a compromise as the ITC only has a small number of correction points and it extrapolates in a straight line between them. This is particularly a problem at times (in the RPM range) of rapidly changing boost levels.
As you increase the amount of power and/or boost this "compromising" just gets worse. With an SAFC and an ITC you have (sort of) fixed the A/F ratios and the ignition timing, but you also have the problems of boost mapping, idle stability, load correction for air con, power steering, electrical load, rpm limiter, speed limiter, cold start and run etc etc
If you add up the costs of all the "trickers" it works out more than a Power FC and still doesn't give anywhere near the quality of result. So for a modest power target, an SAFC is not a bad thing, but if you are serious, then an ECU upgrade is the go.
Hope that helps
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745385
Thanks for that reply Sydneykid, my car is also auto and i have a s-afc. But when being tuned on the dyno the tuners had problems with the timing as it caused the car to misfire when they leaned out the s-afc. So if i get my hands on a ITC it will fix my problems? I wish i could get a power fc but im stuck with this problem.
Or would you recommend me to sell the s-afc and buy a e-manage with igniton harness? The only info i havent been able to find out is if the ignition harness will work on the auto with no problems. I dont want to throw any more money around trying to solve it, i just want the cheapest, easiest option which the ITC sounds like it can do.
Cheers,
Matt
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745392
Hi Strutto, if your power targets are modest, then an SAFC is the go. We are getting an auto Stagea shortly and I will stick an SAFC in that. I have a ball bearing hi flow RB25 turbo to go on it, a split dump, 3" exhaust, panel filter, CAI, Autospeed (Norgren valve based) boost controller and an OK intercooler. Should give a nice torquey 200 rwkw to tow the race cars with.
If it doesn't end up meeting my expectations, I might try a piggy back manual Power FC. Leave the inputs to the standard ECU and the outputs from it to the auto. Parrallel up the inputs to the PFC and use it to run ignition, fuel, boost and idle control. I have seen an R33 with a Link piggy backed similarly, it was OK but a little rough on the gearchanges.
Have a chat to Steve-SST, I think he has done a Wolf into an auto.
Hope that helps
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745401
Well once i get the ecu issuses sorted out i plan on doing the fuel pump, fuel pressure regulator, cam gear and then finally highflow the T3. I think that will be enough power for me so is a safc and itc good enough for this setup? Thanks again, Matt
Yep, sure it's a compromise, but not that bad. I had a friend with an SAFC and ITC and he was happy for 3 years, driving everyday + some drag and circuit work.
https://www.sau.com.au/forums/topic/6309-safc/page/2/#findComment-745413
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
