Redline Performance Cruise For The Salvos – Biggest Event Of 2005 13/03/05
the cruise it going to shikjuku.
BTW my favourite line was this:
we are on show to the country via channel 9 to show them that the modified car industry is not full of hoons and people that care about the community.
apart from that good luck with the cruise. good to see someone trying to do something for a good cause.
  • Replies 121
http://forum.hot4s.com.au/messageview.cfm?...&threadid=30013
Date: 13th March 2005
Meeting point for sydney : P6 carpark
Time: 10:30
Meeting point for central coast : To be advised
Time: 11.00
Meeting point for newcastle: Newcastle Knights stadium carpark where there will be a representative of the cruise in charge there
Time: 11.00
The final destination is at Bateau Bay sports and rec fields (also known as EDSACC).
well i guess that means us coasties will be at edsacc at 1130, no use going to the twinys cause then it would mean going up to warnervale doing
"u" turns and coming back down the free way.
unless we meet up with the newie crew on their way down the freeway.
That's what we've done every other time man... just shoot up the freeway from newy, turn round after the caltex and then come back down the freeway to the caltex going back towards newcastle... it's easy :P
ne more know what time the cruise finishes @ s.o.p cos  i need 2 b  @ the superdome  4.45 pm.
gtrsrule - Not sure when it will finish but as a guess i would say 16:30 to 18:00
I guess we are leaving Sydney @ about 11:00 to meet up @ Wyong @ 12:30, does anyone know?
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
