  • Replies 184
Hey just watch it RuTismo, im in here now too. Happy to go heads-up with you any day buddy.......
Oh and talking about racing I will just miss out on this event but come Drag Combat I predict the BU5TER will be on a strict diet of dirt garage GTR's :headspin:
https://www.sau.com.au/forums/topic/63261-compak-attak/#findComment-1195496
Guest two.06l
who's who I though we had seperate usernames now???
im sure dave will provide some stiff oposition. Butt i think that Pauly will be a bit more of a match for the B...U..5...TER..lol
https://www.sau.com.au/forums/topic/63261-compak-attak/#findComment-1195501
Guest two.06l
Sorry dear?  You're gonna have to speak into the slower of my two ears...  Maybe your voice can bounce into it off my rear-view mirror!!
Adrian
the only thing that will save you from Pauly is ANDRA......11's are lame.......10's are were it's at!! track ban here we come! No ban........no marriage!! hehe
https://www.sau.com.au/forums/topic/63261-compak-attak/#findComment-1195558
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
