you can put any type of speaker in any car lol...
6x9's should fit in any back dash, the only car we had problems installing 6x9's to were my friends gen 3 prelude, we had to cut the metal on his back dash and also cut the 6x9's LOL, but in the end it fits nicely and sounds sweet :)
https://www.sau.com.au/forums/topic/63580-6x9s/#findComment-1195641
I tried but I'm not that great at it.
With 1 set of spacers it was very close to hitting the metal surround of the car.
Ended up not doing it and getting 6" round ones.
Got a spare set of 6x9's now if anyone wants to purchase??
Pioneer 3 ways, 240w i think.
https://www.sau.com.au/forums/topic/63580-6x9s/#findComment-1195731
yes there is, leave them out
sell them to some guy on ebay or something.
6x9's r a generic oval speaker which tries to play sub bass. by using them u'll be taking away quality bass that ur subs should be playing. Esp. if u have them just off the headunit.
IMO sell the 6x9's, with the money u get from that buy $100 worth of sound deadening for the front components u have. will sound much better IMO.
but......if u really want to use the 6x9s just make a spacer out of mdf.
https://www.sau.com.au/forums/topic/63580-6x9s/#findComment-1195912
check out my thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=62816
When i did mine i replaced the entire shelf and made a new one but you don't have to do this...
Roughly steps I took:
1.Remove rear seat
2.Remove stock speakers
3.Remove the Masonite timber panel on rear shelf
4.Remove everything form your boot - including your battery
5.Unscrew your HICAS Unit (this will need to be moved)
6.Get in your boot with the 6x9 template, mark where you want them
7.Use a angle grinder to cut away the steel - this is not allowed as it's a structual part of the car but you wont get done for it or anything :)
8. Once cut make sure no sharp edges, then try the speaker - if it fitst cut the top timber panel to fit (or make a ne wone like i did)
I helped my mate do his yesterday - took about an hour, should take you about 2ish if you aint done it before - maybe more if your scared of the sparks form the grinder :)
Method B is to buy some 6x9 'blocks' from say autobahn (or make your own) they do look a bit shitty IMHO but some people like them :)
https://www.sau.com.au/forums/topic/63580-6x9s/#findComment-1195937
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
    • If you are getting that sort of fuel usage, you might as well be back in the stagea
    • Looks good mate, those stainless lines must be a bastard to do neatly. Better get it to a track again sometime soon, I'm doing to Wakie day next Wednesday to see if the v37 likes cool weather better than hot weather....
    • If you've got spark, and you've got fuel, it needs once last thing to go vroom... Have you compression checked the motor?
