Time to sell the Skyline
It’s a white R33 GTS25t manual 4 door type M
It was imported two years ago with 70,000km and was auction grade 4 it now has 98,000 km, I have serviced it every 5,000km using Motal oil.
It is essentially stock but has Whiteline suspension bits in it and I have just spent $600 getting the windows tinted.
It also has a tow bar rated to 850kg that I had fitted to tow my motorbike (only 300kg).
Apart from a few minor stone chips on the front bar this car is immaculate; I have even had some people think it was a new car. I don’t think the back seats have even been used. It has been kept under cover day and night and barely even driven in the rain.
I love this car and don’t want to sell it but I need something I can use to tow my rally car. I have just paid the rego and have a valid RWC for it.
$16,500 ONO
I am in the outer north east of Melbourne and the car can also be viewed at work in Campbellfield.
Mob: 0439 304 903
Chris
  • 3 weeks later...
You dont have to be in Melboune.  It's repalacment came from Perth
sory mate, i couldn buy a car without test driving it or at least lookng at it. ;) and i don have the time to travel to melb...
will you be able to tell me what options does the car has
any modifications
does it come with RWC
any rego!
tell me your last price
to tell you the truth i can get one imported from japan for $16000
and the importer will even modify some stuffs after compliance
cheers
Kev
It has a Whiteline works suspension kit that consists of up graded sway bars, caster and camber adjustment kits, Bilsteins shock, lowered Whiteline springs and a front strut brace.
I have also fitted a HKS Turbo timer.
It comes with RWC and 11 months rego.
You may well be able to get one imported for $16,000 but you don’t get to see what you’re buying, you have no idea if the mileage is correct. You will also find that if you order now you could well be waiting many months for the car to be shipped due to the massive rush that is on to buy and ship 15year old cars as a result of the impending rule changes. i doubt that price included on road costs so you can add another $1000 or so there.
I have reduced my price to $18,000 I am checking to see if any of the suspension bits can be transferred onto my new car if so I will drop there value off the price.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Someone come any buy it this weekend I cant fit the new car in the garage now.
where did you get the tow bar from as i have been told you cant get them for 4 doors....pm me with details please (desperate) wheres it bolted to???
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
