K just thinking of putting my R33 back basically to stock then flogging it off for like 15-16k.
So here we go.
3½" Turbo back exshust made up of a KSP turbo back with screamer pipe, pretty sure its a highflow cat (can take pictures if anyone is interested to see if you can tell but i would say it if it its on this bigger system), HKS Super dragger cat back with the Super Dragger cannon with a HUGE chamber and tip.
The system is a really nice deep note PERFECT for the R33 GTST and bolts straight on. The exhust is perfect for anyone who wants a VERY high quality straight system without being really loud. It is very quite on idle and only roars when the car is boosted up :D
The Exshust system new would cost around $2500.
I only want $1000 PLUS a stock exshust off an R33 GTST.
Set of 4 17" Enkei Lightweight 3 peice forged wheels. White.
These wheels are Very rear and would be one of the only sets in Australia. They are unable to be bought in Australia.
The sizes are 17X9 for the front and 17X10s on the rear.
The wheels ALSO come with NEW tires worth $900 alone.
The rears where replaced about 6 months ago with Khumo Ecsta Supra 17/40/255, and the fronts where replaced a week ago with Wanli 17/45/235 so neither front or rears would have to be replaced for ages.
These Wheels are very light and would fit any R33. Same stud pattern as other skylines R32, R34, 200SX etc. Stud pattern is 5 X 114.3 I do not know what the offset is sorry.
If you are interested you are welcome to come have a look at them in person.
NEW would cost around $5000 then tires ontop need tires.
I want only $1500 with a set of wheels to replace them with with good road worthy tires.
Hybrid Front Mount Intercooler with all Chrome pipe work, clamps, Silicon hoses etc.
This cooler kit is about 1 month old so is in perfect condition. No fins have been bent or anything.
Bought for $1500. Sell for $1000 with a stock R33 GTST cooler and top pipe, brackets and other peices removed to put on the FMIC.
WHOLE CAR AS IS NOW FOR SALE WITH EVERYTHING $18500 ono
http://www.nissansilvia.com/forums/index.p...showtopic=71445
WANTED: R33 GTST front bar in white to replace mine which has been cut out for the intercooler.
If anyone is interested send me an emails to [email protected] SMS or call me on 0402 756 302 or just send me a PM.
Also have some audio gear if anyone is interested.[/img]
hey mate. yer i got a duel stage turbo smart but i think im just going to leave the car now as ive got someone intersted in buying the whole car...
"Specifics on stereo gear? I'm after 6x9s and amp" ill send you a PM
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
