hi,
I had a drifty into a stobi pole with my 32 and the stock cooler got smashed. Anywayz, im gona fit a trust cooler now and i was wondering how much KW at rears i will get. The modifications will then be:
K&N pod
Blitz spec S dual SBC boost controller - will be running about .92 of bar (about 13.5 psi)
3" mandrel exhaust
& ofcourse the trust cooler
Close to stock, but ive heard that it will be about 150 at wheels, im not sure ( thats y im asking :mad: )
TY in advance to who ever replies,
-Bryan
https://www.sau.com.au/forums/topic/63918-quick-q-about-intercooler-r32-rb20/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
