I'm after some common used aftermarket R33 stuff
Like:
Single Gauge pod ( A-Pillar) for an autometer boost gauge, (the larger of the two common sizes (60mm i think) I can't find one of these anywhere :(
A decent 3" exhaust, old school style, and not the new-fangled cannon style. Something brandname, just like this:
http://www.upimports.com.au/UPI_Parts/Pics.../Exhaust_10.jpg
Anybody got a basic set of used Kings/Pedders lowered springs?
A HKS SSQV with adaptor flange for a R33 GTST, in decent cond. Looking for a cheapie for this, so cosmetics aren't important, for the right price of course.
A set of BLACK 18x10 japanese rims, dish not all that important. This is a longshot as i'll prob source some from an importer, but i thought i'd test the waters here first.
With the exception of the single gauge pod, there are any number of places to source this stuff, but I thought i might put the feelers out in SAU first. Lemme know what you've got
Thanks Guys :bananaman
