662GDO you will need a fuel system upgrade to run it properly (pump and iunjectors) Z32 afm, you wont need internal work. If i didnt have the GT-RS i would snap this up in a second! Great Buy! Good luck with the sale!
  • Replies 54
thanks, i am running a walbro pump and it seemed to be up to the task pretty good. Might get away with standard injectors and riseing the fuel pressure abit but i didnt want to risk it.
wat mods did you have to the car besides the turbo. i am seriously thinking about this. mines got fmic, apexi power fc, z32 airflow meter,oil/air seperator and intank bosch 040 fuel pump. would it run 17psi safley on those mods with 550cc injectors and bosch 044 pump or will i have to do some internal work.
any help would be appreciated.
thanx will
i was running a wolf with smaller injectors 480cc and standard internals. had no dramas.. you have everything you need there to run 17psi safely probably even more boost if you wanted
well it all bolts on, only thing you need is to make dump pipe with a 4 bolt gt30 flange, if you have aftermarket one now its eay to modify so wouldnt cost much. then all you need is oil and water lines which would cost prob be around $150
it is also on ebay and finishes in less then a day if you would like to bid on it there. starting bid is 2100, so far no bidders
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MESE:IT
should stil be pretty good, would be abit more laggy then on a 25 but i dont think it would be to bad. would be alot better then say and old style t4 turbo. should be able to get you 250 rwk on a rb20
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
