heavy duty upgraded clutch will cost you around $700 fitted.
Normally $600 but the gearbox in those is harder to remove than the GTST.
Some people may do it cheaper. Make sure you replace rear main seal, spiggot bush and carrier bearing when you do the clutch also. Also make sure you ask the people doing it if those items are included in the price - they should be. If not, you are getting ripped off.
You can get a whole range of other clutches so really the prices go up from there. All I can say is do your research and specify what you want outta your ride and it's driveability. Once the clutch is replaced it will be too late if it's too hard or grabs too much or not practical on the street. You'll basically need a clutch to match your mods and HP.
Your car will be off the road for a whole day and possibly two if they are really busy or run into any unforseen problems.
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
