Nissan Skyline GX 1986
Auto
280,000kms (serviced every 5,000kms for the past 5 years of me owning it)
Mongoose car alarm and immobiliser
Exterior
Sky Blue over grey paint
17’ DTM Wheels (Perfect offset, NO Spacers)
Bridgestone Potenza SO3 tyres up front 215/45/17 80% tread
Silverstone tyres at the rear 215/45/17 75% tread
Front Lip spoiler with air vents and mesh
Series 3 front end and series 3 tail lights w/ garnish
Tinted windows
Projector Headlights
Import GTS grille
Interior
Sports Steering Wheel
Autometre Boost guage in chrome cup
Sports pedals
Custom SKYLINE seat covers
Turbosmart dual stage boost controller
Suspension
Lowered King Springs
Front shocks: Pedders Sports
Rear shocks: Billsteins
Whiteline Sway Bar
Whiteline Strut Brace
Engine
RB30ET
Hiflow T3 (Only a few months old and polished with match ported dump pipe)
LINK ECU
Bosch 036 Injectors
Bosch 040 fuel pump
Oil Catch Can
Front Mount Intercooler with 2 ½ and 3’ piping powder-coated in black
3’ Exhaust Mandrel bent from the turbo back with hiflow 3’ cat
Battery in the boot
Engine Cosmetics
Polished Inlet manifold
Polished rocker cover
Chrome fuel rail
Polished power steering fluid cannister
Polished bonnet holder pole
Driveline
Yarra Valley Auto (Built less than 2,000kms ago. Can handle BIG Power)
Exeddy Trans cooler
1 piece 3’ tailshaft
LSD
Brakes
Slotted front rotors with Lukas Pads
Stereo
Pioneer head unit
Pioneer 6x9’s
Pioneer Splits
2 x Audioline Amps
12’ Kicker boxed sub
I also have a manilla folder jam packed with receipts and history of the car backing to the early 90’s. This car has had over 20k spent on it and has been looked after to the extreme as I am a perfectionist when it comes to my car and everything is done right.
The car is currently making 150rwkw but this is due to the intercooler and the intercooler is just a truck core and is not flowing enough. With a new intercooler and some minor work the car should make 200rwkw with ease, and most importantly the car is all prepped up to handle massive power as the driveline is all complete.
Things to do to make this car complete
New intercooler with piping $1200 (You could sell the current setup for about $600)
Respray the front lip of the car $100
That’s it!
As mentioned I have poured so much money into this car and everything is done spot on,. When something has broke, not only has it been replaced, it has been upgraded if possible. Theres just a few minor things to fix and you will have a weapon of a car.
PRICE: $12,500 without plates
Car comes with RWC & Rego til April
Serious people call me or pm me
Chris - 0412 757 886
https://www.sau.com.au/forums/topic/64784-vic-r31-skyline-slywpn/
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
