1994 Nissan Skyline R33 GTts, Mods Inc
EAST BEAR GTR front barand grille & Gen GTR clear indicators
Type M side sirts and rear pods
Gen GTR Rear wing
Bishop Blue paint (includes engine bay, doors and boot)
Tinted Windows
UAS custom airbox,
Custom dash (silver with blue pearl, also guages were lighter and ashtray were)
Carbon fibre steering wheel
Recaro Seats front and rear
Rays Volk Challenge Wheels (white with silver inserts) 18x8 and 18x9 rear with new falken tyres
Tein HR coil-overs supension
Nismo Mini locker
BeeR full exchust 3.5 inch Turbo back & Jast Jap front pipe
Nismo clear side indicators
ENGINE MODS:
Full rebult motor with
Shot and pined rods
semi forged pistons
O-ringed
machined crank
porter head/maifold and inlet
Hybird cooler (600x300x70)
S/S cooler pipes
Hi-flow fuel pump
SAFC2
Apexi turbo timer (pen type)
Samota Air filter
Standerd Turbo/injectors (V/G condition)
Custom Blue Airbox and rocket covers
Brand New 5puc button clutch with GTR pressure plate
86K on the Clock and less then a 3k after rebuild
Will not separate anything, no time wasters pls,
$28500 reg til Nov 05
180kws on 10psi,
Call 0400261099 or PM
https://www.sau.com.au/forums/topic/64799-electric-blue-r33/
Beautiful, beautiful car, I'm always a sucker for a blue car with white wheels! Does it for me every time!
Just one quick question though. You can't get semi forged pistons, there's simply no such thing. That or, either your understanding or interpretation of "semi forged" is wrong or mine is.
I beleive forged pistons are milled and machined from a single forged block of billet steel.
Cast pistons are created in a similiar fashion, but have the majority of their lower skirt structure created in the initial cast, and then receive milling and machining, to get create the crown, skirts, dish, fly-cuts, etc.
So what sort of pistons do you have?
Mate that is a very good question,
all i know it that there bigger and stronger then the standard ones in a RB25 by not a full forged piston the engine was done by custom engines in melb but i will find out the exact name and type and change the post.
Thanks for the info.
Cool.
Sounds like a very durable/tough engine, with the calibre of those strengthening modifications! I'd say it is definitely capable of enduring a little more punishment than 180kws.
The next owner will be able to bolt on a larger turbo and (with the appropriate tune) chase much, much larger numbers, with out any major concern. I'd have thought an engine that strong could be capable of producing around 300 rwkws. But I suppose you'd be better to contact "custom engines in melb" for their much more valid opinion.
Far out. I am in the process of getting 2 skylines resprayed in the new XR6 Blue colour. Same as this car. Also with white wheels : ).
This colour is becoming very poplular. Suits the skylines. But with the drift (Stealth) wings :/
Nice car buddy.
Nice car buddy.
The colour is Bishop Blue, Toyota Rav4 and Ecco colour, not ford blue. very similar tho, thanks for the thumbs up.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
