Pictures at: http://members.optushome.com.au/domeye/4sale/
Prices Are Firm: Will do trade for other goods of value.
Call 0401698552 or email [email protected]
Rims
14" White Oz Racing Rims + tyres (4 x 114.3) (195/55/14)= $550
Stock r33 rims with tyres (100% thread) $450
Stock r33 rims with tyres (70% thread) $350
Stock r33 rims with tyres (20% thread) $250
Pursuit Rims with Soft Compound Tyres (off r33) = $295
17" White Rims Semi-dish off a s13 Silvia (4x114.3)= $645
18" Forged lightweight Rims (18x9 all four rims) with tyres = $1900
18” Multispoke Polished Alloy (multi 5 stud) with tyres = $1500
Audio Equipment
German 800watt Amp (4 channel) = $295
Kenwood Double Din Headunit with Stacker = $500
Pioneer Double Din Headunit = $300
6x9 Speakers Sony 160watt = $85
6x9 Speakers Kenwood 220watt (has small puncture) = $45
2 x odd front speakers = $45
Boxed speakers Pioneer with inbuilt tweeters = $150
Nissan Factory Items
Pulsar gtir floor mats = $145
R34 Xenon headlights with all required accessories: $1200
Front stock r33 suspension (shock absorber) = $95
R33 factory cup holder = $15
R33 Airbox and snorkel (with cut out for extra air flow) = $90
Turbo Timers
Ultra Automated Turbo Timer with harness (gold buttons) = $50
Ultra Automated Turbo Timer with harness (silver buttons) = $50
Automated FET Turbo Timer with harness = $50
Others
Generic Brand Pod filter (no adaptor) = $20
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
