Well - it turns out my R32 was running R32 N1 turbos already – I've just ?upgrade? to R34 N1's.
It's a long story but I already had the R34 N1s when my engine died, and I honestly had NO idea my orginal turbos where N1 too.
Soooo
I now have a pair of R32 Nismo N1s for sale
P/N : 14411-06U00
Comp A/R : .60
Ex A/R : .64
both in VGC (done about 47000klms) no shaft play etc - where running fine when my bottom end gave way :D
I have NO idea how much these things are worth - but I'm watching an eBay listing for a similar pair (.48 Ex housing tho) that is currently selling for ~1400 ish
talk to my ppl - I don't want/need these anymore - and I'm open offers I 'spose
I'd like some input on their value too pls
will clean them up this afternoon and post some pics for anyone interested
https://www.sau.com.au/forums/topic/65100-r32-nismo-n1-turbos-x-2-vgc/
heheh how funny this happened to myself this week aswell everything besides the rebuild bit.. i took mine off to upgrade to 34sn1s and they were 32 n1s on it .. from my research $1500 upwards mate.. good luck with it..
OK
I'm no expert - but as far as I know they are steel wheeled, but NOT BB (someone correct me if I'm wrong)
They are rated @ 300ps each - and I think they should be good for at least 18psi (maybe 20 with a good FMIC)
I was getting a lazy 210awka on my GTR with std everything running 14psi boost (pots 4 and 6 where shot tho). They give good boost early and hold on strong across the full rev range (I have the output of a power run somewhere if you're keen)
They should be good for at least 250-280awkw (good street turbo) with the right mods. Again someone correct me if I'm wrong.
In terms of price - I agree with OoHArrGTR - $1500+ sounds like a bargain to me. I paid almost $3K for my R34 N1s - and when you see the pics (if you give me your email) you can see these turbos are in VGC - I can't get ANY shaft plat at all !! I cleaned them up this afternoon and the look great.
Having said all that – I'm open to offers at this point
  • 2 months later...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
