screw riding a bike to work, my next door neighbour had to all winter cos he crashed his car....
oh and the weather ain't all that bad here, i got on a plane here and off in brisbane and there was no difference...
actually the whole drive down to melb i think it was colder than tassie
Haha, difference was timmy, you probably left here in the middle of the arvo with the sun out, and arrived in bris with the sun down and a shit day. But there has hardly been a winter at all this year. every year it seems to be getting closer to being just one 12 month season.
You BIG girl Tim.
Nothing wrong with riding bikes, there just like cars and can be used in all weather conditions.
Its the rider that can't :rolleyes:
I ride mine and the car is on the road (well most of the time) its easier and quicker to get to work, (and i can have more fun as well) less fuel consumption and i can park anywhere....
I love Tassie weather B)
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
