law, im a law student, but we have to research and work on real cases....kinda like cheap labour for law firms lol....we get shafted....only 1yr to go though.
ahhh i see, so ur kinda a bit smart then eh? ;)
no just someone from tas looking in the thread..
gheybo's :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
