Two Apexi boost gauges complete with tubes and electrical wires, white background with blue backlight and redlight needle.
They are in excellent condition for secondhand items, no scratches on glass or body of gauges. Will post interstate for $5 extra each, or pickup from perth. Contact me on [email protected]
Will take nearest offers if not much interest.
Apexi Boost Gauge with HKS dash holder - $220
Apexi Boost Gauge with standard dash mount - $185
https://www.sau.com.au/forums/topic/65443-apexi-boost-gauges-x-2/
60mm yeah?
Am looking for one of these but can get it at a much cheaper price brand new.
I am in perth and can pick up. If it makes it cheaper i wouldn't need the dash mount
PM me the lowest you would go.....
Hey,
What's the difference between the two gauges apart from the holders? Is the one with the standard holder an older stye (ie. the different negative intervals)? and are the tube and electrical connections the same for both?
Thanks,
Chunners
Price drop! $130 for HKS one and $110 for the other. They come with all connections.
HKS one is worth more due to the coooool rubber mount.
Chunners: they both have 2 wires and the pressure tube. yes the displays are actually different, dont know which one is older, but they both do the same thing.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
