  • Replies 473
no SLOBO......as in SLOW....she is trying to say that he is SLOW around a race track and that he will never beat her.....hence calling him SLOW.
but yeah we all now its a lie....and that slim can easyily OWN her on a race track.......dont underestimate the devo 9
Bwhahhahahahahha
... confusion reins in this battle of SKILL AND POWER...
with the battle lines now clearly drawn.. all that is left for the peeps to choose sides
this truly is the final battle between good and evil....
and im not sure wich way it will go...
SL!M...... Representing the EEEASSSSTSSIDDEEEEEEEEEEEEEEEE
and relying on the race prepped DEVOLUTION 9 to power him to victory..
he grew up on the streets and now hes back to defend em..
MOANIE.... Representing the WEEESSSSTTTSSSIIDDEEEEEEEEEE
moanies RB25.666 powered R33 is shrouded in mystery.. some say that her engine block was forged in the dark funances deep below thornleigh maccas.......
...now for that comment...sl!m will eat you up.
he is dangerous!.....and blonde.
Bwhahhahahahahha
ever thought of writing your own book??
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
