Saw these at the recent Motorsport Show. Im grabbing some for my new bonnet that arrives in a few weeks.
They are available from V-Sport Australia
PO BOX 3096
Murrumbateman , NSW 2580
Ph: 02 6227 5108
email: [email protected]
Their website doesnt have any pics of this product and a search of the forum didnt reveal anything so perhaps skyline_geoff can post a few pics?
https://www.sau.com.au/forums/topic/65782-aerocatch-bonnet-restraints/
They are plain old bonnet restraints...ever seen boonet pins/latches. Well they serve the same purpose but are massively over engineered and look trick. And they dont stand proud of the boonet 1 inch like the typical bonnet pin:thumbsup:
Mind you they are $30-40 mor expensive then the typical bonnet pins, but they are so cool:)
