New Cyber shop
Guest Blurple
Hi guys & gals
I need your opinion on a few things -- and please only constructive comments - thanks
There is thought of opening branch of cyber in brisbane. A shop that does body-kits, wheels, stereos, interiors, rice bits (steering wheels, mats, neons, flexi-glow etc etc) pretty much everything except hi-tech preformance.
What i need your opinion on is these questions:
1. Do you think the market in Brisbane is big enough for another player??
2. Would another shop mean more competition in the brisbane car scene ie at jambo, bas etc?
Thanks very much - i await your comments and suggestions :)
Blurple :burnout:
https://www.sau.com.au/forums/topic/6582-new-cyber-shop/
Based on your description, YES do it, so long as it is done correctly you should be fine. I will give you one piece of advice.
Never bag another shop to a customer
e.g. Yes we do body kits, ours are much better than ARES speed kits, theres are ****.
This is the one way to send you business bankrupt. I visited a certain chilly (think about it) workshop at the coast and they told me that their fmic were much better than those from ARE, infact ARE actually use our designs. They didn't realise that I knew this was total crap and they lost my business and the business of my friends, all up 7 intercoolers, oil catch can and a overflow bottle, all because they told me crap and bagged another well established business just to try and get their foot in the door.
If I was you and was looking at starting a business in Brisbane here is what I would do. leave the body kits to others, unless you have the time and expertise and good labour kits will be your worse nightmare as the time and effort that goes into them is not matched by the amount you make on them. Get your self affiliated with someone like takakaira and sell all the Cool Jap accessories, videos and magazines. Rice is bad for your diet if you eat too much so other avenues seem to be taking off like the before mentioned mags, vids etc. Real merchandise like apparell from MINES, ENDLESS etc is also a good idea and will give your business an edge, if your shop is the only one that sells it then you will make the money.
Look at the trends, where is the Ozzy car scene heading? If you wait till it happens its too late, you need to be established and on everyones lips so when someone says where can I get those cool ????? that I saw on that vid then youe name comes up straight away.
One last thing, don't try and make tonnes of money by selling a few items. My opinion is that it is better to sell 100 $2 items than 10 $20 items. The more product you have on the road and on people the more you name gets around so don't charge to much, aim to sell quantity.
Sorry for raving but starting a business is something that I have looked into fairly seriously in the same area as your self.
https://www.sau.com.au/forums/topic/6582-new-cyber-shop/#findComment-98292
Guest Boxhead
exactly right cameron, this sale may not be made on customer service, but the next ones will be...
always aim on not selling one product to the customer, think of what theyw ill come back with the next time...
as they say customer always comes first..
also from a customers point of view, if you dont have something in stock or ever get it, be friendly and suggest another store who you know has them.. i know from experience that when that happened to me, i was more then happy to go back to the original shop for anything i wanted, coz i know that if they didnt have them, they would pint me in right direction...
and if your looking for an employee, give me a yell.. ill do it!!! come on.. dammit give me a job...
https://www.sau.com.au/forums/topic/6582-new-cyber-shop/#findComment-98441
Guest Blurple
I would not bag another shop.
It's to give bris-vegas some more "friendly" competition - Ares and DMD turn out some great work - throw a cyber shop in the works and every Bas and Jambo people will have something more to look forward to - to see what each shop has new :D
Thanks for your opinions - they are greatly appreciated :uh-huh:
Anyone - please post comments asap
haha - boxhead - we will keep you in mind :D
https://www.sau.com.au/forums/topic/6582-new-cyber-shop/#findComment-98730
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
