Things we can do for non-car related fun?
just wondering what people would like to do?
go-karts is a definate especially if this wet weather will hold out :D
tobogan park? (its past my area near farms but is pretty damn cool)
push my colt to my house from a few suburbs away?
but yeah anyone have any idea's? i have no more damn weddings so i can most likely attend
(change of topic to make akeenen look like a fool and for me to look supirior muahahahahaha MUAHAHAHAHAHA MUAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
ok i just checked and the actual topic didnt change so now i suck
paintball rocks.... got so many HS last time and ppl were getting pissed off with me :) so i shot them in the back of the head LOL
its like real life counter strike... and i had my head shot script on max haha
um did anyone miss this
non car related fun .!!!! now read the suggestions doxximus put forward who also wrote the thread..
it seems as though non car related fun is virtually impossible!!!!
:D )
AHAHAHHAHAHAHAHAHHAHAHHAHAAHAAAAA
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
