What voltage should I be getting in a R32 (RB20DET)? I believe it should be at least 14V but I rarely get 14V :D My last car got a healthy 14.4V. Mine struggles with electrical load. If I turn on the a/c + headlights it drops it down to about 13.3V, if I brake it'd drop down to 13V :O
Any suggestions? I got my alternator replaced last year as it died, and I've got a 12 month warranty on it. Reckon it'd be worth getting it replaced?
https://www.sau.com.au/forums/topic/66057-whats-the-standard-voltage/
No...those voltages are fine. 14.4 v is bordering on overcharge.
At idle with no accessories it should be between 13.5 - 14 v
With high beam on it should drop roughly 0.05 - 0.15 v
With A/c and highbeam on it should drop a further 0.2 v or so.
When you hit the accellerator it should recover to just under your idle unloaded voltage.
With all accessories on at idle, 13v is ok.
If you are reading a voltage of a handset or something of the like, you will find that there will be a difference between the voltage displayed and the actual voltage.
They are not terribly accurate but in most cases are within 0.2-0.3v
If it drops below 12.8 volts with all accessories on, then replace it.
If you have any doubts, take it back to whoever fitted the alternator and ask if they wouldn't mind re-checking it for you. I'm sure they won't mind.
Yeah, grab a multimeter. You may be just expiriencing voltage drop where your timer gets its source or earth from. I wouldn't be happy with my alt dropping to dead on 13V with a few of the accessories on. If the battery is fully charged I would be chasing 13.8V. If it is dropping work out how many things you have running (big stereo?) and see if your alt can handle it.
The alt I have on the r33 runs at about 14.5 Volts up front, by the time it gets back to the battery in the boot its down to around 14.2-3.
readings at where though? from the back of the alt whilst its running?
Check your earth leads, especially around the chassis earth. Do a simple voltage drop test on your earth lead. Same with the positive. When I say voltage drop test - as in from the Pos on the bat to the pos on the alt whilst under significant load. Should have a tolerence of about 0.3-4V if higher fix it, if lower, its good.
I could go on for hours, but finding a voltage drop can take ages.
Cheers
Sumo
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
