Hey All,
Having troubles taking my stock R33 steering wheel and putting a new one on. I undo the cover from the stock steering use a hugeee rachet to undo the bolt in the middle but i can't? am I doing it right? you undo the middle bolt after taking the cover off to take the stock steering whee; right? :)
https://www.sau.com.au/forums/topic/66103-taking-steering-wheel-out/
I haven't done a r33 specifically, but there should be a big nut - around 22mm. They sometimes require a bit of persuasion. Once you have undun it, leave the nut on a few threads, otherwise you it comes time to pulling it off you will smack yourself in the face. Start by squirting some cats piss (WD40) on the spline and let it soak, then get your knees under the bottom side and push up and towards, and pull like a catholic school boy on the top.
When I flies off you will be glad that the nut on the bottom saved a dent in your forehead. :)
Cheers
Sumo
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
