Last night I was driving normally and then came up to a hill and said what the heck and felt like giving it a good thrash. Anyway I reved my car and dumped the clutch but a few secs after moving I was like wtf why isnt my wheels spinning and the cars moving. I tried to push in my clutch as I was coming to a stop sign and realised my clutch was all the way stuck at the bottom!! Only other time ive felt this is when my clutch cable snapped on my civic. I couldnt put my car into gear for bout 1 minute then it jst popped out and was normal again??? Only thing is my clutch feels a bit softer and i cooked it harddddd!! The clutch smelt all the way home and when my car was in the garage the smell was there for at least an hour.
Did i wear out my clutch alot just then? And why would the clutch stick to the floor????
https://www.sau.com.au/forums/topic/66122-weird-clutch-problem-info-plz/
with your pedal stuck to the ground, this sounds like a hydraulic problem (master cylinder or slave cylinder or both). Yes other cars use a cable clutch but skyline uses hydraulic.
To get your master cylinder reconditioned with new seals and stainless steel sleeve if needed is about 70-100 per cylinder. Mechanic can do this for you or you can give it a go yourself, i tried it myself and ended up stuffing up the master cylinder again so for $200 or so save the hassle and let a mechanic get it going for you.
With the clutch - any idea on the wear on it? is it new? old? due for replacement?
I had the same problem in my daily driver ( aus R31 ) about 3 months ago although I wasnt caining it. Just driving along and all of a sudden the pedal went to the floor.
Stuck my foot under it and popped it back up.
Never had a problem and it hasnt happened since.
yeah dude, i had same prob in r33 gtst. Went to do burnout with some mates in the car, revved, dumped clutch and car didn't move at all just revved like shit. Went to put clutch in and realised it was still stuck all the way down. Same thing, just popped out after a few secs and smelled like shit. Clutch then started taking heaps far out. That was a few months ago and i've been nice to it since. Still i think the clutch is gone and probably a hydraulic problem.
Let us know what yours turns out to be man
Cheers
He means the clutch wont engage or grab until the peddle is almost out at its furthest point.
Check your clutch fluid level.
I had the same problem in one of my Integras, it was the clutch master cylinder..
Yeah my friend had a similar problem with his DCR2, but his clutch has done 100,000+! so its due for replacement, anyways he couldn't put it into gear, then we got it checked,
the clutch fluid was low, they topped it up, no problem since and his still driving dunno how the hell the clutch is lasting so long for him, he drives CRAZY!
Kriminal this happened to me 2 nights ago. My car is still off the road and had my mechanic have a quick look at it at home (didnt jack up the car), he said possibly the clutch fork is bent broken or out of place, or maybe the pressure plate has collapsed
did something the same went to pop it and then found that I couldnt select gears (no clutch) waited for it to cool, no good, I had to drive home with no clutch so learnt to match rev quick. Found problem to be that pressure plate weled its self. Came unstuck with some help from 2nd gear
Yepo, this happened to me only 3 weeks ago..
Took car to mechanic, 2 things were wrong..
1) I had a tiny slit in the rubber connect hose from clutch cylinder to master cylinder pipe..that needed replacing $15....(situated under car, under drivers seat)
2)the actual steel pipe that holds the clutch fluid from master cylinder (under the hood) down along firewall to the slave cylinder, under the car was not in the master cylinder far enought therefore, air was getting in under pressure, therefore clutch went floppy...
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
