Basically took the wheels off, & knocked out the center cap from behind, as I wasnt painting the center cap.
Got the sand paper out (medium grade) and sanded back all the paint on the part that I wanted to spray. After I got it down to the layer of primer, i basically washed the wheel in soapy water, and let it dry.
Once it dried, i used scotch tape (3M) to tape up the inside of the rim, and the edging of the tire, to prevent overspray on the areas that dont need spraying.
I used an Arcrylic based paint to do the job. It was a 400ml can made by "Holts" and its called "Dupli-color" autospray. Its actually meant for touch up paint on panels of your car etc, however I decided to use it on rims.
Shake can well, or leave in sun abit, and then spray it in coats, till your desired finish comes up. Leave about a 10min gap in between coats, as it gives time for the paint to stick, before applying the next coat.
Once finished, wait for it to dry, approx 1 day to dry, and peal off all your masking, and wallah!
All 4 wheels will take approx 3 cans of spray, ie 1.2L in total.
Hope that helps
Thanks for the comments guys, I found that everyone either had silver or white, and just wasnt happening for me anymore!!! Could have gone bronze, but wouldnt look right on the wheel, but im happy with the black! Looks evil! HEHE, Getting carbon bonnet soon to match the rims and also abit more lowering front and rear :rant:
ive also contemplating getting the spokes on my rims black. At first i was thinking of taking it to get powerder coated, but this seems cheaper and more satisfying. Atm they are shadown chrome with a bit of dish, so black spokes against chrome dish would look smick. Car is also white too. The only thing holding me back is if i start sanding them then there is no turning back. Any necessary tip that i would need in order not to ruin it.
Just mask up your dish right, and youll have no problems! Make sure you sand back the chrome paint on the main spokes, but will look hot once done :cheers:
Number one tip for a good finish, is to always take your time. Dont be impatient as it costs you more time.
Total cost was 3 cans of spray ($45) , plus sandpaper ($1.20)....
Im not too sure if you did powdercoating, whether you can actually still mask it up???
But this is pretty cheap and effective :rofl:
thanks mate. I was intending to get them powerd coated but think this is much cost effective way with the same outcome. Does the paint give the rims a very nice gloss coat or does it look dull as i cant really tell from the pics.
Its a nice gloss coating... If your after gloss, select "Gloss black"... If your after a flat finish, such as an aluminium or plastic look, select "flat or Matt black" Those colours are usually dull, but can give a nice appeal too :cheers: Makes your rims look like they are made of some trick alloy or titanium, lol
ive going for gloss black. Ive used these gloss matt black paint from vht i think it is on my intercooler piping and it was very nice.
If its still sticking to your cooler piping, I dont see why you cant use it on your wheels :cheers: HEHE... The only thing that you should worry about, is weathering and whether the paint will stick to the wheels.
As long as you give it a good sand, and make sure you get paint that will bite into the metal, and also be weather resistant, your pretty much set.
The stuff I used was car touch up paint, which is pretty much meant for panel jobs...
I will be using a proper metal primer so no paint sticking problems as long as I've sanded it properly.
So looks like you will be painting your rims too.. Do post up when you actually finish the job or one wheel :rofl:
Guys, you can add a primer coat, but I think its probably only necessary if you sand your wheels back to bare metal...
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
