Just got my car back from APC after getting a dyno tune.
My car is a 33 GTR, mods as follows:
Nismo RS580 turbos (300hp)
Apexi powerfc
Custom 3" exhaust system (only twin 2 1/2" front pipes though)
100mm intercooler core
HKS cam gears
700cc injectors
044 pump (intank)
Avcr boost controller.
K&N pod filters
RB20/25 air flow meters.
Result: 315hp at all 4 (235kw) at 17psi :thumbdwn:
Whats a stock gtr have at all 4? 180kw? 35kw more seems a little less for the work done. To me the car doesnt feel like it had 1kw more then what it did when I dropped it off.
Personally i was expecting around 280-300kw at all 4, fair enough if it was 270kw or so but to me 315hp sounds pretty low for the mods it has, its about 40 more rwkw then what my gtst had with standard turbo, ecu, fuel, nothing basically. Nothing compared to the money ive spent on my gtr anyway.
Basically they said the boost controller takes too long to get the boost, then it dies off early and doesnt hold it, it has full boost maybe abit after 5000rpm and holds boost good (which I thought was normal for these turbos) it doesnt drop off from my experience driving it. They suggested I buy one of their turbosmart E-Boost thingys but I cant see that getting the power up to what I thought it should be.
Does this sound right and if so what should I change (minor money, as im basically over this thing now) to try get the power up alittle, im thinking 3" front pipes and a cold air setup, but I cant see that adding a real lot either.
If it doesnt who would you recommend on the southside I could take alook at the tune for a second opinion.
Cheers :cheers:
https://www.sau.com.au/forums/topic/67595-does-this-sound-right-dyno-results/
What 1/4mile time would I expect with that power, maybe a mid 12? it seems alot of money to me for half a second off when I ran a 13.2 in it dead stock.
I used to run HKS 2540's at 14 psi and the car made 351rwhp (260rwkw) back then, with the standard intercooler and front pipes.
How can I get the same (if not less) power after adding a 100mm cooler, more free flowing exhaust, and nismo turbos at 17psi that spool 2000rpm earlier?
This is def .02 cents worth and i must say i have not researched the nismo turbos for even 1 second but from where i sit i would put the blame on either
1. the turbos or
2. not enough boost for the power you want, now if apc reckon the air is getting to hot at 17 psi to make any more power then i would def say the turbos are to small for what you want. However they may be perfect for someones elses aplication. Surely some 2530's would flow 300rwkw.
2. the tuning.. (have heard apc are good tho, so... :Oops: )
good luck mate
Midnight GTR - I wouldn;t waste $$ on 3" front pipes, mine made 355rwkw at the same boost & I've only got 2 1/2 inch ones albeit cams & 2530s & that was on the same dyno. If you reckon your ebc holds boost ok I'd sit on the dyno with them & see if it does - if its dropping boost well that would certainly give bad power figs.
what are you cam wheels set at ?? . If you've got std cams in my opinion adj cam wheels are a waste of time if they are not at 0/0 bring them back to there and do another run I think you will be suprised . I have OS adj cam wheels on my GTR they were already on there when I bought it and we also had un unexplainable shortage of power or atleast not as much power as we thaught .After closer inspection both wheels were set at about 6/6 advance after bringing them back to 0/0 it was a new car.
Too much speculation for me to comment. If you have them, please post up the dyno graphs with the A/F ratios and the boost levels. If they didn't give them to you, I would go back and ask for them. If they don't have them stored on the hard disk (unlikely), then ask for a quick power run (no tuning) then print them out. :cheers:
There is ~300 rwkw (400 rwhp) in that combo, we just need to find out what is holding it back.
get the pipes.
there is free and easy power/response buy putting on a larger exhaust
And yeah, that power figure is worse than a car with stock turbos.
something is seriously wrong.
you can make 300rwkrw easily
that figure doesnt sound right ive got a r33 gtst with a garrett gt35 turbo .63 housing
power fc fuel pump etc. standard internals and its producing 255kw at the wheels.
give buzz engines a call on 07 32794989 and speak to adam he should be able to help you
out tell him marco told you to call i got some of my stuff from them and they are verry
helpfull.....
I also thought 270kw atw at least would be what it should be making..
When I had the 2540's they adjusted the cam gears to try get them to spool as early as they could, and when I put the n1's off the power did drop off alot at the top end but it definatly wasnt the boost dropping, so I figured it was the cam gears set incorrectly for the new turbos.
You would think apc would check the basics like cam gears and timing, but you never know accidents do happen and things can slip peoples minds I guess, is would say the timing is correct but they could have just forgotten about the cam gears all together.
Im not sure what the gears are set on at the moment but tomorrow ill take note and change them back to 0/0 and see if it makes much of a difference. Ill take it to another workshop sat morning and see if they can have a quick look over it and see what could be wrong, but the power does seem to be down alot on what it should be.
Cant really do much for awhile anyway as apc have packed up and gone down to sydney apparently.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
