got a few parts for sale nothing wrond wid them just been upgraded...
1.RB25DET series 1 computer and AFM $120:SOLD
2.RB25det series 2 computer $100:SOLD
3. R33 bonnet with GTR front lip $250
4. R33 standard steering wheel $80
5.R33 standard intercooler $30
6. R33 standard air box $40:SOLD
7. R33 standard grill $50:SOLD
8.R33 GTST standard wheels and tyres good nic, good paint no scratches and bout 50% tread still left $400
9. R33 standard injectors $300
https://www.sau.com.au/forums/topic/67792-r33-standard-parts/
Hey, im just wondering is the bonnet you have off a series 2 becasue i am desperately in need of one because i just had a prang two weeks ago and need one and i will buy it off you asap.
Thanks
Thanks
hey mate im after a rb25 AFM but it has to have a pink sticker on it, NOT green, if its pink ill give u $80 for it as i need it ASAP
call me on 0402 622 317 if its the right one and ill pick it up asap :(
cheers
Brad
Gr33dy your PM box is full, i tried sendin to u but it wont accept!!!!
Yer you can have the to computers and Afm for $250 Delivered!!!!
clear your PM box so i can get some delivery details!
thanx
If you still have the airbox I'll take it. As long as it's complete top and bottom with all the bolts and grommets and also the plastic spacers that go iside the grommets and the clips for the top. Can you send me an e-mail if you still have it?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
