  • Replies 104
Thanks Rev and Aw11
Im not sure whether i need those pineapples as im not getting the diff bounce the other cars are getting...oddly enough this time i managed a 2.23 60 foot.
What i do need is one of them 5Giken twinplate clutches paired with a lightened flywheel!....And a maybe 17psi
Originally posted by macka
Thanks Rev and Aw11
2.23 is still not a world beating launch mate even I managed a 2.1 on el'crapo 205's (didn't make the most of it cause the vacume line popped).
Have you installed the pineapples yet? Reducing diff bounce isn't the major reason you put pineapples on, wheel spin is.
BTW whats was the terminal speed, 660ft and speed and 1000ft time?
Yeah i understand what u mean but last time i couldnt manage any better than 2.5 60 foot
Elapsed time 12.988
Terminal sp    113.35mph
60    2.25
330  5.79
660  8.59
1000 10.98
113.35mph Damn!
That mph is fat enough to get the low 12's on street rubber, get yourself a 1.9 or 1.8 60ft and bingo!
You must have a nice mid range power band dispite the lowish top end power figure.
If you still have the top secret ecu for next time you could run a bit of toluene in the tank to get a jap like octane level and stop the timing retard.
Explain toluene i thought it was cheap fuel?
I raced with 104 Nulon in it to be safe.
How do the bosch pumps go with toluene in it?
Well in my eyes i have a crap mid figure, i lost something like 20HP@wh when we retarded timing back from 20 to 15 degrees at 10psi
Go the pineapples still?
Macka,
Toluene is the cheapest form of octane booster around, Service stations often used it in there fuels as it has not excise placed on it by the government. There was an article on octane boosters in an HPI I have so if you want to know more then I'll look it up.
Octane boosters are cool as you will be able to advance the timinig without causing the engine to ping, but if you use it often it will f#@% your spark plugs.
See'ya :burnout:
Toluene is THE best basis for a turbo fuel full stop.
Toluene was used during the 'turbo era' of formula 1. Back when they were running 5bars(73psi) of boost in qualiying and 4bars(59psi) in race!
The formula 1 fuels were limited to 102 RON so 84% toluene and 16%n-heptane (has no octane rating to bring it back to 102).
Toluene has a RON of 122 but more importantly the RM/2 is 114 which is freakin high.
A 30% mixture of Toluene with BP98 yeilds a RON of 106 but huge RM/2 of 103!!!
The main disadvantage of running too high a mix of Toluene is the cold start and low rpm operation if you don't adjust the maps and timing. Having said that I have sucessfully ran the above mixture of 25/30% in my car with only the factory ecu and I didn't bother changing the timing either.
If you want some the Makit hardware store next to marlows balcatta has some, diggers brand 1 and 4L tins.
Go the pineapples! :(
Rev210,
Looks like you've been doing your homework, I read in an article that it will add about 2.5RON in a resonably safe mix, but is it going to be an advantage if you don't advance your timing? I thought the higher octance rating allows you to advance the timing safely, without pinging, but if you don't advance the timing will it make a difference to the performance?
Thanks for the info.
See'ya:burnout:
Adam32,
I agree totally, I was only suggesting that toluene was a cheap octance booster, and would only really be using it for the drags, the extra cost of adding octance booster during daily driving would be pretty substantial.
Macka,
I think you can get enough toluene to boost 100litres of PULP to 101.3RON for about $48, I have the suggested mix in a magazine I read last night, once I get home I'll post the info.
See'ya:burnout:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
