  • 3 weeks later...
  • 3 weeks later...
  • 6 months later...
  • 2 months later...
Bump again. $9500 slightly negotiable with 1 year rego and AWSN warranty.
If you're from another state, I am happy to credit the cost of rego towards shipping it another city - in order words, free shipping to Brisbane, Melbourne and Adelaide!
Edited by mini2
you've had this for sale for ever, and i was looking at it months ago on this site with mild interest, looks immaculate too, is there any problems with it or is it just absolute bad luck that no ones snapped this up AT THIS PRICE!!!!
Why it's still here? I guess it's something to do with just about the last two dozen or so people that called up, asked for pics, promised they will come and have a look but never turned up. I've wasted a fair bit of time washing it and waiting for them to turn up.
One of the best was, e-mailed me asking will I accept to sell it for their 1988 Cressida and $1k cash. I suppose the main thing is, no one can get over 'it's not a coupe' mentality but then they aren't prepared to pay for a coupe so I guess they never ended up getting anything.
See, that suck's, it has the potential to be as quick as a coupe (minus the auto) with a whole lot of sleeper credibility thrown in, plus i've seen 4doors that look hot as, big rims and coilovers = done, exhaust = got the sound too
I've always looked at 33, 4doors for something different, cause no one has them, it's different, but i want black and manual, sorry
It's a bloody steal, 32 4 door's go for more....
Yeah, people paying more for a 3-4 year older car that's not registered or complied.
EDIT: to clarify one thing, I will do swaps but cash must be my way..so anything worth more than mine need not contact me. Well I wouldn't mind someone hugely depreciate their car though lol. Thanks :P
Edited by mini2
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
