World Record....?
Guest DIRTgarage
In the Dyno shootout comp. yesterday, TWO.06L recorded a mind blowing 627bhp.
which is 467kw. Is this a new World Record for a GTR running 2530 turbos, or for that matter low-mount turbos alltogether. Jim from Croydons is sure it is but we would like to find out for sure. By the way nitrous-oxide running cars do not qualify and must be running on jap pump fuel or equavilent.(we ran VP 103)
https://www.sau.com.au/forums/topic/68548-world-record/
  • Replies 64
Chunky. Not bad for what I heard was a stock bottom end :P
Oh and I doubt that Jap bowser fuel is as oxygenated as the VP gear, how much timing did you end up winding into it?
Good results anyway, time to do some benchpress practice with gearboxes :)
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1270962
Guest two.06l
4% more than what we had?? I think?
don't think we have ever said it's a stock bottom end? We will have different box again for next event, should be better.
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1270985
ill try but im sure it was like 2 yrs ago since ive heard of it
could have been low mount 30's or 28's... cant remember off the top of my head. was almost unbelievable cos u wouldnt think u could low mount those bigger turbos.. but aparently was.
at this stage uve got the record n we will stick to that :P
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271071
or as a quick reference:
Posted by: Guy R
Here are the results from the low-mount turbos, on mine and Henry's car that we both own!
My car (2.6litre, wild cams)
Max on 2530s - 560bhp
Max on T618Z - 672bhp
Henry's car (2.8litre, mild cams)
Max on 2510s - 554bhp
Max on T517Z - 635bhp (only 1.5bar)
Conclusion, from 2 cars on rollers:
The HKS GT2510/2530 will struggle to get 600bhp.
The Greddy T517Z and T618Z are noticeably bigger, still low-mount and easily capable of flowing 600+ to 700bhp.
The above are facts as tested on a MAHA dyno in England.
Guy
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271075
Hey now that you mention it....
Phoenix's Power (http://www.phoenixs.co.jp/bigsite/home.html) have got a few near that power figure. From their power rankings:
1) BNR32 - R34 N1 turbos, PowerFC, cams etc : 645.5PS (636.6HP/474.7kw)
2) BNR34 - HKS GT-SS, PowerFC etc : 634.1PS (625.4HP/466.4kw)
Will check out some others.
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271084
    • I went and found the actual FSM again (Yeah, I squirreled...) Screen grab of the FSM for M35. 51PSi with engine idling.
    • I thought the same too, and more than happy for others to bring another source for what it is. Just throwing so me caution out there, as potentially an extra 30% current needed than expected.   Well worth more investigation, but right now, I'm going over my Cypher knowledge while Expendables 4 provides mundane noise in the background, ha ha!
    • You still around Terry?
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
