World Record....?
  • Replies 64
Guest two.06l
good work!!
whats the lag like on the street? have you driven it with that state of tune on the street?
steve
lag...what lag? its 2530 low-mounts....about as laggy as stockers.....it kicks ass on the street, as well as parks nicely, and even picks the daughter up from school...
