Hello SkylineSAUstralia member, i have the following items for sale.
-2inch autogauge products-
1. Smoke face Boost gauge.
2. Smoke face Electric Oil pressure gauge.
3. Smoke face Electric water temp gauge.
-Stock-
-Smoke face-
-Boost-
-Oil pressure-
-pillar mounted-
-in dash-
-Price-
2 in stock -> boost @ $90
0 in stock -> Oil pressure @ $99
1 in stock -> Water Temp @ $95
Email me on [email protected] if interested.
best regards, Jye.
https://www.sau.com.au/forums/topic/68894-smoke-face-autoguages/
Depending on how many people want them, i can order in another 20 sets. But ATm im just trying to get rid of whats left.
Im sorry i didnt post them on SAU earlier however i wasnt aware of this forum, so most of the products sold to silviawa members. My appologises!
The prices are stated above, but if you missed it here they are:-
Boost = $90
Oil pressure= $99
Water temp= $95
This is just a quote from one of the silviawa members:-
"Nr01:- my autoguage boost guage is pretty much spot on when compared to boost from my dyno sheet"
Put it this way people...If they werent a good product i wouldnt of given them to my friends, i wouldnt of installed 3 of them in my turbo civic, and i wouldnt be selling them...
and just for the people interested i only have
1x boost and
1x water temp left.
-ive had many request for the pillar mounts, so i might be bringing over a few more items next time. So if your interested please Pm soon as the next order will be coming in 7-10 days.
best regards people
Jye
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
