Price drop $11 500 ONO!!!
Hi All,
Selling my dads V8 Soarer for him. Here are the specs:
1991 Model
Rare Burdgandy
Tinted windows
17" ZEIT Mags
187000 kms or so on the odometer
Valour interior
Rego till October
Price: $11 500 ONO
Contact: Marvin
Email: [email protected]
Phone: 0414 627 849
https://www.sau.com.au/forums/topic/69197-fs-cheap-sc400-soarer-sydney/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
