Forwarding this information from a friend.
Understandably, the wheel offset wont suit skylines, but were just letting the word out if anyone hears/sees anything
Hey guys... I had my nice new wheels stolen from my 'secure' underground carpark last night.
Probably through and inside job.
The wheels are very rare and unusual. They only fit WRX's and Liberty/Legacy and they are also fitted with Yokohama DNA GP tires which are only sold in Japan. It is also quite likely that these are the only set of these particular rims in the country as I had them specially imported from Japan.
If anyone has seen a rex or liberty fitted with these rims please let me know when and where as soon as possible.
This is a picture of the rims:
https://www.sau.com.au/forums/topic/69230-stolen-wheels-please-help/
Forwarding again:
For the record...
The wheels are Volk Racing LE37A - 18x7.5 +48 offset. So they only fit subaru cars... they're specifically designed for the Legacy (Liberty) but I'm fairly sure they will fit a WRX as well.
The tires are Yokohama DNA GP - 215/40/18 and are probably the only set of those tyres in the country. You can't buy that model here (same with the rims really).
I've been told that most thieves change the tyres so its harder for owner to identify them though so if you do see those rims anywhere on a car, record the rego and let me know ASAP. The police will help me do the rest from there.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
