Hi,
Could be now that you've said that... I did get a flat battery the other day for no apparent reason... just about sure lights were off when I parked (it was night time) and when i woke up to go to work, no battery power.. hmmm.. i'll check.. but never thought battery would have anything to do with it.
  • 1 month later...
Hey Guys,
Never assume the worst when it comes to misses or stutters.Always check the basics first.
1.Clean coils and check for cracks.Really check.Take coil cover off and look at night while reving engine.
2.Remove filter box and intercooler 90 deg. bends going through inner guard.Boost leaks will give same problem but usually in lower rev range.So look for cracks in rubber.
3.Anybody using a unichip will eventually find out the crank angle sensor does not like to share it`s signal for to long before it will develope a miss.It can also happen to non chipped cars to.
4.Check all vaccume lines against another car if your car has had a mechanic working on it.Check all wiring to.To the mechanics that are indeed professional I apologise.To all you other pretenders, go have alook at Croydon Motorsport Developement just for one day.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
