Here Is Your Chance To Own The Ultimate Gtr Skyline . Vehicle In Mint Condition, Originally Having 8000km When Bought From Japan. Have Driven It As A Weekend Car, Never Raced And In Immaculate Condition.
Nismo Dash
Exhaust System
Purchase Of A Property Forces Sale
A Bargain At $65000.00
Call 0403478170
ask for Jerome
https://www.sau.com.au/forums/topic/69670-gtr-r34-v-spec1999-model-35000km/
Hey guys no silly offers, it is a very good price and you could sell it for more if you have time to market the car. For the record this car is agenuine V-spec sticker has been removed due to someone thoughtless tried to remove it.
$65000.00 ono. best offer between 60k-65k will buy this car.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
