  • Replies 61
nah it's all booked, so as long as we have 12 people we will be fine. I am hoping we will get 24 racers, so we can split up into 2 separate Grand Prixs and take turns in qualifying and racing etc. I spoke with Greg and he was in, but he said Leroy was only a possible on account of his wife :cheers: Will catch up with you soon Matty for a few drinks.
Oh add a +1 for me. I'll most likely be bringing a mate along with his 180SX.
Anyone else going to the SVD Dyno Day @ Tilbrooks in the morning? Figure I might go check it out, not sure if I'll run since I had one just recently, but I could use it as an excuse to play with my boost controller some more... :)
since its all booked and there seems to be more than enough of people doing plus the fact that im a maybe, you guys/girls have fun.
Poor excuse mate, I count 22, doubtless people WILL bail on the day, and failing that you can at least come to the meet/diner earlier on to say hello.
Cummon yah bum you missed the Port Elliot cruise! :)
yep the final venue is Richmond.
We will be meeting at an undisclosed North-Eastern place for early dinner at 5:30pm then mini-cruise to Richmond. Those on the other side of town can just meet us there. For anyone that wants the info please PM me and I'll send you the meeting place and restaurant/cafe details.
Sorry I can't make the grand prix - I didn't realise that Adelaide United are playing on the same night and I've already bought a ticket. I'm keen to meet for the dinner and mini-cruise.
you have to come Duc - we really need 24 people for it to work properly. Come either way, it will be fun.
Yep no worries Matt, Leroy or Greg are of course welcome to come with me - unless Chops is coming with me, then you'll have to squeeze Greg in the back of your car :)
i didnt look at the first post to see the update, it just seemed that alot of people was posting they would come and the fact that they would bring xxxx people along made me think that there was enough. Either way, my gf just read the post and insisted that she also wanted to go - shes never been go-karting, so put me down as 2.
Good work Duc, your missus has the right idea, see you and her on Sat! :)
We don't cruise very often anymore due to the massive police presence and resultant diminished fun etc.
Especially now it's winter you will see many of the Skylines from this site home in their garages.
But keep an eye on these forums, as cruises do happen from time to time.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
