Broken Passenger Window
Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
