Located in Brisbane - Queensland, the items listed below are for sale.
If you would like to beat the rush (I hope...) I suggest calling me as I will not be accessing my email often.
Gav
0403 21 6969
JAP SPEC N14 SSS
5 speed manual
GTIR bucket seats FACTORY
FACTORY bodykit
SR20
Central Locking
Electric Windows
VIPER mags
K&N Filter
$7000
MATCHING #'s DATSUN 240z + PARTS
'73 240Z (LAST OF THE 240Z's)
SILVER WITH RED FACTORY INTERIOR
TOKICO 5 way adjustable shocks
FRONT & REAR strut braces
Original and Vented Bonnets
ALSO CARBON FIBRE BONNETSKIN X1
ALSO F'GLASS FIBRE BONNETSKIN X1
Assorted front and rear spoilers
Bubbles in door bottoms - dent in passenger door - ALL REPAIRABLE - just had to mention it.
Car has been in storage for quite a while with a layerof dust to prove it.
$7000
SPORTS TRUCK - CUSTOM BODY KIT
TOYOTA SURF
Electric Windows and SunRoof
Central Locking
AfterMarket Wheels
Near new tires
NEW Injection pump
NEW springs
NEW shock
NEW rear main seal
NEW head
Snorkel
Auto
2.4 Diesel TURBO
130,000 K's
$12000
KAWASAKI BALIUS ZR 250CC
Reliable Cheap transport
No fairings to break
Easy parking solution
43,000 K's
$2600
HONDA XR250R '97 model (black and red seat)
The bikes reputation speaks for itself.
NEW fork seals
NEW Front tire
As fast as I ever needed to go on the dirt.
$2500
RS - 8 WATANABE'S
HARD TO FIND THIS MODEL - ULTRA LIGHT
15x6.5
PCD 114.3
OFFSET +34
4 STUD
Not sure what these will fit but not willing to run spacers on my 240Z.
$1500
AUTRONIC SM2 v1.93 REVISION
www.autronic.com
Regarded by many as second only to MOTEC - and we know what they cost.
BRAND NEW RB30 TURBO loom
$1800
BRAND NEW - DNA PORTED 12" SUB BOX X 2
BRAND NEW - JBL CS-12 12" 500w SUB X 2
$450
RARE - COLLECTABLE
1/10 SCALE 240ZG RADIO CONTROL BODY - BRAND NEW, UNPAINTED
$120
RARE - COLLECTABLE
1/10 SCALE MAZDA RX3 SAVANNAH RADIO CONTROL BODY - BRAND NEW, UNPAINTED
$120
https://www.sau.com.au/forums/topic/70966-stuff-in-brisbane/
Hi Justin, very perceptive of you to notice. As I said in the ad aswell as the provided www.autronic.com link the CPU as been upgraded to V1.93. This features additional goodies such as Traction Control and Launch control.
I also have the receipt for the upgrade.
Kind Regards
Gav
0403 21 6969
dude that doesnt look like sm2..more like smc??? am i correct?
cheers mate justin
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
