I must admit tha 16th cruise with 8 cars was the best I've been on as no one got lost we followed easily and even when they got way ahead I found them no wuzas. Not beening an xpert I think groups of ten is agood idea would take a bit more org but with uhf a leader could get a group to where it is happenin and cruz would stay in shape. We could have diff groups too like gramps driver group etc.
Its late and im prob babblin tell me to shut up
Shut up :wassup:
  • 2 months later...
JUST CRUZIN
Okay guys sorry about this but we have to call the sausage sizzler off.
RULES FOR JUST CRUZIN
Rule 1 Stick to the times.if you get to your meeting spot an no one turns up please leave at the time you where given for that spot.
Rule 2 Starting spot for the cruise will be the service rd outside yatala bp servo at 12.00pm.if we are forced to move on our next meeting spot will be computer rd yatala behind the brewery or exit 41 leaving there the same time 12.00pm.
Rule 3 If there is no one behind you on the cruise,your going to fast,slow down.unless your the last car.
Rule 4 When we arrive at latimers crossing the first car there will wait 10 mins only,to allow for other cars to catch up.
Rule 5 Make sure you no the route we are taking.dont rely on anyone.
enough rules lets just have a great cruise.make it a day to remeber.we will be leaving the spit at 4.00pm for the cruise back home.
if you dont no the route here it is
ROUTE..Okay leave the service rd at bp yatala take the m1 down to mudgeeraba.Take the mudgeeraba exit.Cross over the m1.turn right at the roundabout follow mudgeeraba rd.turn left at worongary rd.turn left onto hinze dam rd cross the dam wall.turn right onto advancetown rd.turn right on to nerang murwillumbah rd.turn right at latimers crossing,stop at creek for 10min.turn left onto gilston rd.on the third roundabout turn right onto mortensen rd.turn left at the end of mortensen and your back on the m1.take the smith st exit and head for the spit.
meeting spots and group leaders
HARVEY BAY:8.00am...Shan blue wrx tuned sticker seafront oval & 8.40am matilda sth maryborough
TOOWOOMBA:9.00am...Cam yellow cosmo chalks drive
SUNSHINE COAST:10.00...John grey vx clubby kit servo ettamogah pub
ASPLEY MACCA'S:10.45am...Justin blue sprinter aspley maccas
IPSWICH: 10.45am...Brad blue wrx Redbank/Goodna shell
SPRINGWOOD:11.00am....Kev blue vs commy maccas springwood
BROWNS PLAINS:11.00am...Brett green xyGT hungry jacks browns plains
MUDGEERABA:12.30pm...Sandi white r-33 skyline ije shell mudgee
BAHha HAH AH H A HA Hh aHA HhAHH AH HAH hah aH Ahhaaaa,
Sorry I find that really funny, but all in all, good luck, have funny, and drive safely!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
