Heya,
Anyone got or know where a good condition working coil pack harness is that i could buy for r33 series 1
Zoom and most wreckers dont wanna help because it makes the rest of the engine pretty much useless
cheers
Ive got a R32 one in good nick. If you find out that it is the same then i will be willing to sell it.
