  • Replies 51
Originally posted by DR GTR
But  look on the bright side. You will be cruising with us now Dave! woohoo!
I KNOW!!!!!!
That's all that matters. I'm not at Loz's mercy anymore........I can tell him that I actually don't like him & it doesn't matter because I never have to get a lift off him again!!!! :bahaha: :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106040
Originally posted by cereal_jacques
I KNOW!!!!!!
The truth comes out.... :bahaha:
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106044
Originally posted by red900ss
Hey Dave it's raining right now! Go on you know you want to! :burnout:
Dino....If it wasn't tucked into it's safe little garage right now, Sydneysiders would be viewing some of the hottest 4wd burnouts known to man.......
I think tonight might have to be it's christening in the wet......
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106120
Originally posted by ONARUN
i'm just hibernating and saving my cash boys. i'll be back soon with an old school ride. don't ask which one cause i haven't decided yet but it'll be something....
...old:rolleyes:
Get one of these George!
Thay are old AND they rock! :P
Dave, just be mindful of the likley hood of trowelling your new car on it's 1st day. :uh-huh:
https://www.sau.com.au/forums/topic/7157-finally/page/2/#findComment-106126
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
